I am new to Sheet Metal and can find nothing in tutorials about creating configurations of Sheet Metal. Basically I have a box that is 5x6.5x20in long. I need configurations of different lengths. Help?
Thanks Scott. I possibly drew the Sheet Metal Part incorrectly because the only dimension I want to change with a configuration is an extruded feature that i don't see a "this configuration only" button.
If you need to add just one configuration and one dimension change, I would recommenced
Creating a Configuration Manually
Then after you double click on the dimension to edit, expand the arrow to select from which configuration you want to set the value for.
You might also find this post helpful for your future reference.
Are you double clicking the dimension?
Do you not see the following image after double-clicking?
