I'm trying to create a Dispatch Action that will delete a specific file and replace it with a different file, but have the replacing file have the same name as the deleted one. I ran this action originally without the Checkin and Checkout lines, but it didn't work.
After some experimentation, I found that if I checked the file out manually, ran the action, then checked the file in manually, it worked. Therefore I decided to try to have the check out and check in occur within the action, but it gives me an error, saying "the method completed successfully, but returned a value of 'false'. I'm paraphrasing, but that's the gist of it.
Does anyone know what this error means and how to fix it, or perhaps there's just a whole lot better way to create an action that will copy file A to file B, over-writing the contents, but retaining the file name.
I think the problem is %PathToSelectedFile%, because you delete the file. Try to create a variable for the file name. Usually I had the same problem when the some how file name is incorrect.
