Hello, I'm new to eDrawings. I'm dimensiong an assembly and can't figure out how to get the dimension tool to recognize a hole. I can dimension to the edge of the hole using the virtex tool but when I select the hole tool, nothing gets highlighted. On the other hand, I can recognize the hole with the measure tool. I'm using eDrawings 2011 sp4. Anyone else solve this one?
HI Michelle,
Welcome to the forum.
First e-drawing is nothing more then a viewer. Unless you have e-drawing professional
which allows you to red line files.
The only way dimensions come up using the hole dimension command is if the hole was created in
holewizard. Try dimensioning the hole in your model then import the dimensions using insert model items.
