Hi, quick question about using patterns in an assembly:
Is it possible to dynamically pattern parts?
This is what I'm talking about:
Is it possible to pattern the vertical trellis pieces so
that they change dimension to fit between the upper and
lower 2x4s??
Any insight would be greatly appreciated.
Thanks!
You could pattern a sketch and extrude a multi-body part Up To Surface.
Or create the framework as a part and use the Vary Sketch function, then Split and Save the bodies.
Or create the part as a Weldment.
