add derived configuration via DT
Discussion created by Guest on Oct 4, 2006
Attached is a simple part from SW06. The easiest thing to do is create a few configs manually, then have SW autocreate the design table.
Design tables haven't always supported nested configurations....I don't remember when it started....so if you're using an old version, you may be out of luck.
