This is driving me nuts. I created an assembly in 2010. Time goes by no issue. Fast foward to 2011 SP3 and my mirrored part is now nonconcentric. If i open in SP2 and save all is ok. If i open in SP3 or 4 and save it goes non concentric. My reseller tells me it is because SW uses center of gravity to mirror. Im not satisfied with this answer for the obvious reasons. Ive got lots of time into an assembly that i cant use anymore. Reseller says they will alert me of SR status.
Please help. Im getting frustrated with my resellers confidence in themselves.
This is a good response - someone at SW that says they will personally put an eyeball on this.
I just ran into this again yesterday. One of our guys called me over to show me this weird thing that SW was doing. He mirrored a part in an assy and then changed the config of it to one that had an edge cut off for clearance on that end of the assy. When he changed the config, the part moved. The mounting face that was mated should have stayed in the same location, but the "COG" movement pushed the part into the mating part. Not good.
Hopefully this will be resolved as the way it is makes the mirror functionality less usefull and possibly creating errors that will bite people if they don't catch the fact that the mirrored part is off a bit.
WT
