I am using SW2011 with SP3.
Whenever I check a document to the vault, the default behavior of the "Check In Document" window sets the revision(s) to the current vault value with the working copy + appended. Usually I change this to "Read from File".
Is there a way to modify the default behavior of the "Check In Document" window to have the revisions set to "read from file". I would much prefer to have this the default and change it to something else if needed.
You can file this in the "I want to eliminate a few redundant mouse clicks" section. Not critical to our workflow, but would be nice to know if I can tweak the settings.
Thanks, Daen
Hi Daen,
Yes you can change this behavior, it is in the SolidWorks Explorer Settings/Options window. Under the "Command Defaults" Tab. Uncheck the box "Working Copy Default"
