Is there a way to change a feature in one configuration without changing it in the other? Example: the part is a block 3" wide, 6" long, 1/2" high with a round hole in the center. I then add a configuration and change the round hole to a square hole. But the round hole also changes to a squre hole in the original configuration. Using SW ver 9 sp0.
Thank you
Paul
Hi Paul,
You can create another feature with Square hole, then u can configure the features.
For reference see the Screen shot attached.
I would upload the part file if u want but i have SolidWorks 2011 version.
