in this example iwanto to changed dimention from 50mm to 70mm in sheet 1 then in sheet 2 the 100mm chenged to 70mm
thank you
If this is related to your other thread just show the dimensions of the parts
in your assembly and create equations using the dimensions
that give you the values you need.
