Hi.
Does anyone have any experience wrt Microsoft Dynamics and Enterprise PDM and the integration between the two?
In other words, sharing of information between the two programs by using XML or any other type of connector.
If so, please could you state which connector you used (the ones I saw were quite dismal so far!), or whether you used XML, and if you used XML, how much time did you spend to set it up?
Also,
- what kind of information were you able to share between the two programs?
- Did you share information in only one direction? i.e information was only imported into Dynamics
- or did the flow of information go both ways?
Thank you in advance
Justin Webster from Inflow Technology put some videos together on this topic on our blog. Here is a link: http://blog.inflow-tech.com
