We make quite a few sheet metal elbow segments here and I have done quite a few, however I would think that there got to be a quick and easy way to do this. I have my model setup in a 2D or if it's twisted a 3D sketch, then I make the segements depending on the requirements, (radius, length etc..). Is there someone out there that uses a macro or an excel file to do the parts and assembly?
Thank you in advance,
John Stoltzfus
I presume from your post that this is a product you make all the time. I can't tell by the pics what size this stuff is, but I'm guessing 2' diameter and 14 ga thickness - am I even in the ballpark?
I can't think of a better way to make it physically. My thoughts on the model are that you generally will have straight sections between curved sections. A master model 3D sketch for the bent ones and a 2D for the "flat" ones is, of course, what you have stated you have. How do you get from your master to the job specific one? I am thinking that maybe you could have the path sketch, and then each curve segment sketch also. Then add a surface to each segment, thicken it, add the parts back to an assy to be welded. This way you would have everything all built and it would update all the way through the parts and the wlmt just by changing the dims in the 3D sketch. This is the way I build chutes that are handling coal for power plants.
Or am I not understanding the situation? :-)
WT
