I have a simple assembly created and it uses linked dimensions and equations. I have been trying to change a linked dimension and Solidworks closes out every time. Does anyone have a suggestion as to what might be happening?
Something to check is whether you can do math in a regular dim dialog box. Try 2+3 or something. If you can't then the vba stuff is not working and that may be a clue to your crashing.
WT
Hello Kelly and welcome to the forun,
Do you really mean SW2001 or is it SW2011?
Glenn
