Hi
I would like make a slot on a bending bracket (see below), but when I set flat pattern on this bracket, it like this (see below), which is not real slot. I tried to make slot on the flat pattern, but it didn't show when you bend the bracket (which after flat pattern command!). Anybody know how to make a real slot on flat piece and when you bend the bracket, it will show this slot cutout.
Thank you very much
Ping
Instead of putting it after the flat-pattern feature, add an Unfold feature, put the slot in (make sure you use normal cut) and then add a fold feature.
WT
