Ok so PDM has been giving me some interesting problems.
I accidentally upped the revision on a few parts/drawings, so i was doing a good few "roll backs"
now Roll back is on the same tab as Delete which as i have found out is REALLY dangerous!!
Now while doing this mass "roll back" i accidentally Deleted a part.
the part went from the Tree. and the Drawing Dropped to be at the same level in PDM as the top level.
I then opened the Assembly the part belongs to. It opens fine. even tho there is a part "missing" from the assembly, The only thing i can guess is that it retrieves it from another assembly in the vault (when really it shouldn't).
Ok so tried to check the assembly back in and it went in, it said it was checking in Said deleted part as a New part.
However in the tree it was the same. No part in structure and the drawing out of the structure.
Next i deleted the Drawing and repeated the open and check in.
This time it placed the Part and Drawing Outside of the Assembly.
So 3 questions
1)When the part is deleted from the Tree in PDM where is it getting it from and why?
2)What was going on with the check in
3)How to i Re insert this part and drawing which is now outside the tree in PDM back in?
Ok i Rang our VAR who was excellent on this topic!
Ok so a number of Answers and how to check them and solutions
Answer to 1:
When you open the Assembly that has the "deleted" part in Go to File>File References. This will list all the Parts and where they are coming from.
In PDM these shouls ALL be your Temp PDM folder (in my case there was some from the file where it was input to pdm from).
If the part is being found in a exterenal File, either Raname that file, or Zip it. so solidworks cannot look there.
Then close the assembly and open it. the parts should now be Suppresed as solidworks cannot find them.
2:
If you have the Drawing but no Part, Open the Drawing, and Re check it in Probably best to do this before Renaming the file it can still be found in!
3:
How to re-attach a part/asm that is Outside of the Tree in PDM. open the Part in solidworks, Open the Assembly of which it is missing. and unsuppress because the part is in memeory, it will find it. you can then save and check it all back in.
Hope this helps someone in the future
Joe
