Hi folks,
I searched the forum and couldn't find exactly what I'm looking for. I have my custom templates setup for part, drawing, and assemblies. They are correctly linked in the folders and default template system settings.
If I begin a top down assembly and select Insert "New Part", the part template it uses is nothing I can recognize. It's 6 place decimal metric and none of my templates are remotely close to ASNI metric that is being used at the default inserted part template.
Where is this template stored so I can replace it with my own custom template?
Carter
If you select the option to prompt you to select a template does it give you the option to select the template you would like to use?
