I have a set of Equations happening on a Bearing Rail, everything is going well. Change the length, and the number of mounting hole Instances update accordingly. The Offset from the end is determined by the overall length / hole pitch. (60.0mm Hole Pitch.)
The Linear Pattern explodes on me though if an OAL value is entered that is divisable by sixty without a remainder.
"A"= INT("OAL@PROFILE RAIL"/60) (=# of 60mm Pitches, A+1 = Number of Instances)
"B" is the Remainder. If "B" is less than 8.5, the afore mentioned Explosion occurs.
"C" is an adder.
"NUMBER OF HOLES@LPattern1" = "A" + "1"
"NUMBER OF HOLES@LPattern1" = "A" + "C"
If "B" is Less Than 8.5 "C" should be set to 0, if 8.5 or Greater "C" should be set to 1.
(IIF "B" < 8.5,"C"=0,"C"=1)
Above is the Equation I came up with.
1.) Can I do this with the IIF statement?
2.) What is right or what am I doing wrong.
Before post hogs swarm and tell me to search or give countless references I've already looked at, yes, I already have, thank you very much, don't bother.
Those with concrete examples or suggestions, Thank You.
Regards,
Alan
Jeremy,
No, I don't.
"A" + "1" was current
"A" + "C" is what I wanted to replace it with.
I finally got it worked out...
Thanks for the response.
