How to create custom BOM with sizes of part?
You can create a custom property in the parts that is linked to dimensions in the model and then link the column in the bom to the size custom property. See the Picture
Hi Timothy
Could you explain how to link part dimensions to the BOM? I tried but couldnt.
Monika
Simple show up the custom property window. Then click in the value/expression box and then click on the dimension in the graphics area.
Dear Timoty,
For link dimension in column,
Like Length dim x Width Dim x Thickness dim. isn`t it ?
if each dimension have coma value, is there any setting to change only one or some number limited behind coma.
Like 1000,12345 x50,3456 x 20,789 change befome 1000,1 x50,3 x20,8
Yudika
How do you link the column in the BOM to the sizes of the part?
You can click on the dimensions in the model to add them to the Value / Text Expression box.
Cheers,
Anna
