I noticed that I can drag an excel spreadsheet into a model and it appears there and is editable. Therefore, can you also do the same with a design table....have it show in the model?
The part model is an "interactive" tool used by non-SolidWorks users. So, to make it as easy as possible, I wanted to have the spreadsheet visible. Then they can change the values and see the results.
Not the end of the world but I enjoy trying to figure out how to use SolidWorks in ways it probably wasn't intended.
use Configuration Publisher for that: http://help.solidworks.com/2011/english/solidworks/sldworks/allcontent/solidworks/core/configuration/c_cfgpub_overview.htm
Take a look at https://forum.solidworks.com/thread/14544 for an example.
Have you tried DriveWorksXpress?
Glenn,
Call up the DT and save it out as an Excel spreadsheet.
Then insert that into your drawing.
I hope you are not planning on editing your model from the
inserted drawing DT, because that wont happen.
