When I insert my BOM in a drawing the part numbers are not in sequence. Is there a way that I can rearrange the part numbers, e.g., 201,202, etc...
Thank you.
Thank you.
Diego,
Just grab the end of the line (like where the 26 is in the image) item and drag it to the order location
you want it. If you get a yellow right angle arrow while dragging that is a sign that it will allow you to move
it to that location. If you get the red circle with a line through it then it wont allow you.
Understand that it will only allow you to reorder as long as it does not
break any parent/child relations.
If you RMB on a column you want to sort by, "Sort" is in the context menu. You have Ascending/Descending options, and even 2nd and 3rd column to sort by choices, and can group assemblies and parts together.
