Good Afternoon,
I am trying to open a step file that I recieved from a chassis manufacture. I am unable to complete the task for some reason. I either get a memory error or SW just shuts down. Does anyone have any ideas?
Brett
Good Afternoon,
Brett
Welcome to SW forums Brett
Can you share the file or more info on it. Like size for e.g. as without the file or some info it may not be possible to through any balls towards you.
You may try changing the import options for step files. File > Open > Change file type to STEP. Click on Options and then check/change settings and finally try importing again.
You might also find this post helpful for your future reference.
Deepak,
I have tried adjusting the settings before I open the file. Still no luck.
The file size is 159 MB.
What would be the best settings to use for a file of this size?
I had to sign a confidentiality agreement with Ford Motor Company in order to get the file so I would rather not post it.
I am running SW Premium 2011 SP3.0
Any other help will be greatly appreciated.
Brett
Brett,
Give us your computer spec and operating system. Sounds like you are running out of memory with the big file import. Are you using a x64 system?
Cheers,
Anna
Anna,
Here you go,
Dell Precision M4500
32 Bit System
Intel Core i5 CPU
4 GB Ram (3.24 Usable)
Window 7 Professional
Brett
Unless you've done the "3GB Switch" trick, only about 1.7GB of your memory is actually available. The OS reserves half for itself unless you have enable the 3GB switch. Enabling the 3GB switch may help, it also may cause other system stability issues. Installing more memory will not fix the problem either, a 32 bit pc will only recognize and use 4GB of RAM...even if you have more installed (and of that 4 GB, only 1.7 to 1.8 is really "available").
To quote the great Tim (the tool man Taylor):
"Looks like you need more power!"
If you increase the size of your pc's virtual memory, it may get you by for now. Or you may need to find someone with a more powerful pc. My boss often has problems like yours but I have no problem opening the same file that shuts his down. His pc is not even close to the monster on my desk, performance wise.
Doug, my pc has 12 g of ram in a 64bit version of windows 7, when i load the step file, solid does an analisis of the step file, but when it's finished solid only opens a empty assembly , with no components, or solids. Can you give me any advise?
Can you upload the stp file to here? It could be an "empty" step file, or it could be that the step file does not contain any surfaces (but may have lines/arcs/curves/splines/points). When you go to import the file, check the import options for importing step files. Is the "Free point/curve entities" box checked? If that box is NOT checked, and the part has no surfaces/solids, than SW will "open" it but make it look like the file contains nothing.
