We are working with a part in Solidworks that is imported from another program. One of the planes is way out in space while the other two are fairly centered in the part. Is this just how the part is made or something to do with Solidworks importing? And can these planes be moved? And can the origin too be moved?
You can move the entire part using move/copy bodies and then create the required planes. If required save as IGES/STEP after setting the part and re-import again
