hi all,
there are a number of methods use to stiffen a flat sheemetal panel such as ribbing, crossbraking etc. curious to know what you use to increase the stiffeness of the panel w/o adding a significant amount of material/and or mass.
looking forward to your suggestions.
best,
dave
I believe it'll depend on the area under consideration and application where that part might be used. For e.g. you may use cross break on flat surface and ribs on the bends.
