I try to create a replicated server and when I try to install Archive server I receive a error message that can not create Root folder.
Host server 2008 R2 64b
Please help!
Please help!
Hi Faur.
Not being able to create a root folder typically means that you don't have write access to the location where the root folder should be created, which is C:\program files\SolidWorks Enterprise PDM\Data
That sounds like:
- either an overzealous group policy
- or an overzealous firewall
- or some overzealous antivirus / control setting
Go to the destination folder and see if you can create a folder manually. If not that would most likely be your problem. If you can, then something is blocking the archive server installation, which would lead to points 1-3 above
Hi Faur.
That sounds like:
