1 Reply Latest reply on Oct 29, 2006 12:36 AM by
    Status Code:8 FILE_ERROR
      Without seeing the file, the most likely culprit is insufficient disk space. If freeing up HD space doesn't solve the problem, you should run that past tech support.
      Good luck!
      -- Vince
        • Status Code:8 FILE_ERROR
          I'm running a thermal analysis in Cosmos (using temperature dependent specific heat) and am receiving a Status Code:8 error. Does anyone know what this is and how to overcome? Thanks
