Hi all,
I've just updated to 2011 sp4 and now desgn tables seem to be going wonky.
I created a table and configs in a part yesterday & saved. This morning, on opening, SW tells me there's nothing in the table and deletes it, leaving me with just the configs.
Also, in another part yesterday, deleting a dim from the table didn't unlock it in the sketch, had to delete the sketch dim and re-do.
I have used design tables a fair amount and never come across these issues till after the update...
Anyone else having similar issues?
thanks
Joel
Joel,
Yeah that is a good one. I have never experienced such DT troubles as
when I went to 2010 and above. With that said I have seen more stability
with 32 bit machines then 64. What are you running?
Can you share your file?
Check out this thread that talkes about the locking dimension issue with DT's
Are any of these dimensions in equations?
locked sketch dimensions and design tables
