Could someone have a look at the attached IGES file.
I want to know if after importing into SolidWorks this multi part is at correct scale.
This Assembly was saved out as an IGES file direct from X-Steel.
However when I import this file into SolidWorks i have noticed that the scale is wrong.
Instead of being 9000mm long it is only measuring 900mm, so it all wants scaling up by a factor of 10.
However when I go insert - features - scale, and select bodies and give it a scale factor of 10 the multi body explodes.
Some parts scale while other do not.
I have used IGES files from X-Steel quiet a lot and have never had any problems until now.
I have never had to scale IGES files before they have always imported at 1:1
If someone opens up this IGES file and the length is 900mm rather than 9000mm then I will know that there has been an error in how it was saved out by X-Steel.
However if the scale is correct then there is an error on my computer, possibly a changed setting.
Mark (SolidWorks 2011 sp4)
