Hi all
I'm working on an Aluminium part that has to have a bend starting at the line in Sketch5 toward the R1400 edge. I need to put a 50mm radius and the bend should be at 30 degree from the plane of the surface, and to the right (looking at the isometric projection).
I am not that shilled at doing this kind of model and I would appreciate if somebody could help.
Thanks.
Well you already have it modeled up so you might as well use what you have. I would do the following:
Use the convert to sheet emtal tool found on the sheet metal tab of the command manager. Slect the large face of the part then enter your thickness.
The part is now a sheetmetal part, so click sketch bend. it will ask you to select a sketch so click on the line going across the part then selecte on one side of the line that you want to stay put because what is on the other side that you pick from will be bent. Make sure to clear the option use default radius if it is not set to 50mm.
