I want to project a point, circle from one assemby to another (enclosure). It's to create a cutout on the enclosure. I'm trying to optimize the location of the hole by projecting it.
James
James
Welcome to SW forums James
If the enclosure is in the same assembly, then edit that enclosure and start a new sketch on the face you want to create the cut out on. Now using Convert Entities tool on the sketch toolbar, simply project the circle, point, etc. on that face and add the cut out as required.
You might also find this post helpful for your future reference.
Hi James
Attached is a quick video of one way of projecting features in an assembly from one part to another.
This was done using editing a part in an assembly.
You could also start a new sketch on the part which requires the hole and then use convert entities to project hole, then extrude cut, note if you use this method make sure you check the Propagate to Part' box, otherwise this new hole will not show up in the part file.
Mark
SolidWorks 2011 sp4
Hi James
Mark
SolidWorks 2011 sp4
