DBDariush Bastani17/06/2011
Hello everyone,
  I am going through API Help and find an example for above action, also I am bring it here:
Change Referenced Configuration Example (VBA)
This example shows how to change the configuration of a component in an assembly without opening the part.
Option Explicit
    Dim swApp                   As SldWorks.SldWorks
    Dim swAssy                  As SldWorks.AssemblyDoc
    Dim swSelMgr                As SldWorks.SelectionMgr
    Dim swModel                 As SldWorks.ModelDoc
    Dim swComp                  As SldWorks.Component
    Dim RefCfg                  As String
    Set swModel = swApp.ActiveDoc
    Set swAssy = swModel
    Set swComp = swSelMgr.GetSelectedObject5(1)
    ' Debugging only
    RefCfg = swComp.ReferencedConfiguration
        ' Change component config to "in-use"
    swComp.ReferencedConfiguration = ""
        ' For changes to take effect
    swAssy.EditRebuild
Now in my assembly I want to without opening a part , change the configuration to a specific configuration and it apply to current assembly. How can I do that or what should I put on Bolt expression on above Macro?
