I created two parts, I add rotational axis of each part. Now I want to make two part rotate along the same virtual axis.
I attach the picture and parts, please help
Not totally understand what you mean
I create "centerline" on each part (.prt file), can I use the centerlines to in the asm file to do concentric??
If the parts are concentric, then it is simple, simply lock together a plane from each part that intects the axis of rotation. If the axis of rotation for each part is different, you can create two planes for each part (either offset or not) that create the axis of rotation for each part, then lock a plane from each part.
Lock together two planes whose intersection makes the virtual axis.
