Dear all,
the outline of a hole or outlines of holes, often show up as visible in Solidworks when I would expect them to be invisible.
This problem occurs in both drawings (on screen and printed) and in rendering of parts and also assemblies (as shown in attached png image file)
Obviously if a part is transparent the hole will show through, but the outlines are visible even through solid metal with the transparency setting
very definitely set to OPAQUE (or whatever the equivalent user interface wording actually happens to be)
When there are one or two holes and I'm creating a drawing to be printed I just go around individually telling each spurious outline to "hide"
but what can I do in an assembly (where the hide function seems less obvious - can't find it)
or where there are so many holes, I don't want have to individually manually switch them on and off (hidden or not) according to
which viewing angle I'm using, or where I've placed other parts.
Any advice welcomed.
It is the cosmetic thread annotations showing through that you are seeing. You can prove it by turning them off and then you don't see the holes. In the HW you can pick the icon that doesn't have the cosmetic threads.
WT
