Hi all,
I'm currently running a simulation past an airfoil at a high Reynold number of 6*10^6.
I have messed with two diffferent settings, whereby I used the default comp. domain and then another with a much larger domain ( so I dont get flow interaction with the boundaries) .
The resultant forces are considerably different.
Now I do want more accuracy but with a 1.8 GHz processor and 3 GB of RAM I'm pretty limited, a typical large domain calculation took me around 30 hours the other day.
Also, Im running it for a physical time of 1 sec, would increasing that time lead to a better accuracy ?
Thanks for your time, any input would be appreciated !
If it is an essentially a 2D problem I would suggest you use that function and your compute times would drop to mere minutes even on your hardware. However if you are after the induced drag a big domain may or may not be required depending on the velocity of the flow. Tuning the mesh and using the autoadaptive functions might be a good idea to reducing computational times. It is relatively well known that the Flow sim turbulence model (K-e) starts to diverge from reality in and around your R'number so you should be aware of that.
Why wouldn't you be running a steady state analysis?
