Hi guys,
I have come up an issue I can't work around. I have an assembly with a BASE and PART. I want the PART to follow the shape of the base. However I have tried to add a motor to the simulation and it spins the PART away from the course of the BASE. Path mate seems to only work a point/vertex of the PART.
The simulation will be like a snake along a path. This animation will mean the part will be changing shape and I dont if solidworks can handle these types of animations?
Can anyone help?
Michael seems like your part are different than what you need or you're not able to explain the need.
The part has an in-context relation with base part so I'm bit confused with your needs.
