I need to make an assembly of approx. 100-150 of the same part. I basically need a linear pattern, but I want each instance of the part to be rotated a certain amount. Is this possible? Does anyone have any good ideas about how to accomplish this? I think you could do this in Part mode by preforming a sweep with twist along path. Is there any similar operation in Assembly mode?
Thanks!
Sorry, I did not look close enough at the assembly to notice the axises were not colinear. The only accurate way to do this might be using the API to "Copy with Mates".
