Sheet 1 has assembly with an exploded view and balloons; there is also a BOM of the exploded assembly. The following sheets have the parts (1 to each sheet) contained in the exploded assembly on sheet 1. I would like the BOM to have a column that states which sheet each part is on, yes I can do that manually but is there a way make this happen automatically?
That functionality is not built into SolidWorks. You would have to use the API to do it.
