In previous versions it was possible and now get over defined problem.
I have inserted the part... try to dimension the circle to be 400 mm.... Radial dimension
Brad,
Welcome to the forum.
What version are you using. I did not try your model, but since 2 of us have successfully done
it I didn't see the use. What steps are you doing in trying to dimension the arc?
Are you just selecting a normal dimension and selecting the arc? or are you doing a different method?
Works for me. How are you adding the dimension?
