I have a chain link that I want to pattern so that it goes around the I beam. There is a guide at the top that it is supposed to follow, but the rest is unguided. Im not sure how to mate and pattern it so that it follows the guide but also moves as a chain around the ibeam.
Tracy,
Questions similar to yours come up quite often. Look at the "More like this" box to the right and see if you find a solution for your particular problem. If that doesn't do the trick, try searching on "chain link" or "chain curve" or "chain pattern" or some similar phrase. You'll get lots of hits.
Jerry Steiger
