I am trying to import an .IDF file from Orcad into SW2005
with circuitworks lite. The board outline and components translate
very well, but the cutouts and holes do not translate. Has anyone
figured out how to do this?
I don't know if you have the answer yet but try this,
If you open an IDF file there is an option button available.
click on the button and the import options window appears.
Select IDF. Here are two settings available. One is
Add board drilled holes
were you looking for.
Select IDF. Here are two settings available. One is Add board drilled holes
With regards
Joop
SW2006 SP5.1 / SW2007 SP3.0
