We have the following issue:
We have an assembly with a few sub-assemblies and parts. When we modify a part in a sub-assembly, and then open the main assembly, the changes is not reflected in the main assembly (the sub-assembly reflects the part before modification).Although, when we open the sub-assembly, the changes to the specific part are reflected. We then save the sub-assembly and re-open the main assembly, but, again NO changes on the sub-assembly (part in sub-assembly reflects NO modification). It seems that changes made does not update through each and every folder that the part are saved in.Could this be a setting etc. in the system? We are using Solidworks 2011 SP03.
Regards.
Chris Botha.
Hi Chris,
Did you try Ctrl+Q (Rebuild) In Subassembly and main assembly?
If you have Configurations in model Check which one is currently active in assembly?
Check the reference of the model in assembly as that is same part you looking for?
AD
