I see that this question has been asked before from people like myself who are PRO/E users, trying to learn SolidWorks, so I appolgize for asking again. However, I feel that either I am not finding a answer that works, or is way to over complicated.
I need to create Isometric view for exploded assembly drawings.
Most of the previous post appear to state just orient the view till it looks good, and save that orientation.
Sorry, that is not good enough for me.
I am required by standard (company and customer) that isometric orientation be at a specific rotational value (45/35.26/30).
For example, from PRO/E I can orient a model in a Right Side view, and change the rotation by the values above, then save that new view for reuse.
The dialog box for this looks like this:
So my question is:
If I am oriented in a normal (right) view, is there a way in SolidWorks to create a Isometric view that is rotated in the H (45), V (35.26), C (30)?
Thanks in advance for any help
Hi Joel,
If you hit the space bar you will see all of your current view as out of the box.
When I personally do my exploded views I just spin the model in the view that works
for me, hit the space bar and at the top is a selection to save that view. You can also use the arrow
keys to change the view rotation as well.
http://help.solidworks.com/2011/english/SolidWorks/sldworks/LegacyHelp/Sldworks/Display/HIDD_SELECT_NAMED_VIEW.htm
