I am in my second year at university (BE Mechatronics) and we have been set an assignment to model a casing for a surface mount printed circuit board. We are expected to design the mold for the part so it can be inction molded (We will not physically create any parts however). I have no experience in design with regards to injection molding / flow design etc and before I go ahead and create my mold etc I am hoping someone can have a brief look at one of my parts (Attached below) to suggest any crucial changes or flaws that my design would encounter during the injection process.
Please ignore the lack of filleting on some edges, these will be filleted later when all geometry has been checked. I am really just looking fo any pointers with regards to the layout / general design. Also which direction would be suitable for the plastic to enter the mold?
I really have little idea about this process so any information would be greatly appreciated
Best regards
Liam
ps
The 'Top' file attached is my piece in question, the other file is an assembly drawing
Welcome to SW forums Liam
Yes the part can be injection molded but you need to do some more action on the part. I'm not a regular injection molding guy so expect more suggestions coming in:
1 The part doesn't have proper drafts which is a very important factor for plastic parts. This article should help you to understand more on it: http://www.paralleldesign.com/moldability_101/draftangles.htm You can run the draft analysis from View > Draft Analysis and then add the proper draft to you parts.
2 Try to maintain a uniform wall thickness wherever possible. as this will help in proper filling of the area while injection molding.
3 Do a search over Internet or refer some books to understand more on plastic part designing. You will find these articles helpful:
http://www.xcentricmold.com/design_guidelines.html
http://www.brighthub.com/engineering/mechanical/articles/45260.aspx
http://www.shapedesign.biz/plastic_part_guide_tips.html
http://www.chplastics.com/chblog/5-tips-for-quality-plastic-part-design/
You might also find this post helpful for your future reference.
