Since our Implementation of EPDM in 2008 Users connecting from Remote Replicated Archivers have indicated ‘slow performance of the PDM Vault’
The performance hardships are
Within Soliworks
File > New =
18-30seconds to present the dialog box to select format/start parts which are stored in the EPDM Vault
File > SaveAs =
12-20 seconds to present the Diaglog box of Green vault folder, which the user can start browsing to the new save location
File > Save = 12-20 seconds (new model) to present the Dialog box of Green vault folder, which the user can start browsing to the new save location.
Slow transitions
Slow Folder Browsing in the Explorer Vault View
This issue has not gotten better or worse with various verions (Epdm 2008, 2009, 2010) of EDM or SQL in our 3 year history of this product.
My question Is whether this Normal/Accepted performance for clients using Remote Archivers? Do customers using remote archivers experience these delays? We need to increase our performance to Clients using Remote Replicated Archivers
In the past our users have accepted the poor performance, in order to gain the benefits of PDM, however this in now no longer the case.
Our infrastructure is :
1 Dedicated Solidworks PDM SQL Server SQL2008 (Database) at Corporate Headquarters (5-T1lines -EVPN fully meshed network)
10 Remote EPDM Archivers EPDM 2010 sp4 (there files are stored on the remote archiver) WAN connection to Remote Archivers are typically T1 or 2-T1 circuits. SQL ports 1433/1433 are defined as COS3 with full burst as needed. All remote ARchivers connected to the SQL Server at Corporate Headquartes
The PDM Accounts are using the Windows Authentication
Significant PDM Security through PDM Groups is used
Current Version= EPDM 2010sp4 – 10 remote archivers
75 Solidworks users with RW access to the Vault.
350 clients total (most View/print consumers)
SQL Server 2008 on a Windows 2003 Server Server 8GB memory
EVPN WAN connection to Remote Archivers are T1 or 2-T1 , or E2 depending on the site size 5-T1’s at Corporate
We Have tickets open with Solidworks, it is confirmed that our SQL Server is NOT a bottleneck, no SQL sizing, performance issues of concern. Our carrier has reviewed our WAN links for saturation. There general statement is, “If you see similar performance in off peak times, we would not consider it as a WAN circuit sizing issue”
We have Riverbed appliances in several locations, we do not see an increase in performance. We do Not have the ‘sql component’ enabled. Riverbed as indicated the SQL componet requires custom code and have mixed results in performance gain in SQL Traffic.
Each of the functions above must communicate with the SQL Server in order to produce the On Line (green) vault folders. Solidworks has indicated a small amount of latency will cause the performance we are seeing, however our performance does not improve marketable during low wan usage. As expected the EPDM Performance is acceptable locally to the EPDM SQL Database
Experiences from Users using Remote Replicated Archivers would be appreciated.
Hi Susan,
You do not say nothing about the computers on replicated sites. What configuration and are used, are dedicated only to PDM activities?
We have such problems when on server, on replicated site, there are many opened files. On that server there also also electric projects (not in PDM) and when our colegs open these projects, directly from server, we have problems with slow response of PDM. Usually a electric projects can have a lot of small files.
We will move all the electric projects on other machine.
