Would anyone be interested in checking the results of an analysis? I have made a few thermal runs of a water cooled chamber, and the temperature results I am receiving are tending to be higher than emperical results received from a similar system that was built and tested. A check of the input would be good, and also if anything critical may have been left out in the setup that would result in less accurate data. It appears to be covered, but an explanation for the difference in this analysis and previous testing is desired. Thank you.
