HI guys, I have done some searching as well as looking at both the luxology and solidworks websites/presentations on modo 501 with the sw plug-in vs. photoview 360. I understand they are based on the same technology, but I was curious if there was a reason to get modo over photoview 360. The ironic thing is that modo seems to be able to do everything that Photoview 360 can do PLUS more, and yet modo is significantly cheaper than photoview 360. Why would I buy photoview 360 over modo? Any input would be appreciated.
Kumar,
This question is really about what do you want to do with it. Are you doing quick renders? Then PV360 is really hard to beat - assuming you have Solidworks already. PV360 2011 has a decent amount of control over materials and such and you can also do animation using the Solidworks motion editor. Although, I would say if you are wanting to do animation, you should look at getting modo with the Solidworks Kit.
The price difference you are seeing isn't apples to apples. Solidworks is a parametric modeler - used to make real stuff. modo is a very powerful visualization tool used to make stuff look real. The awesome thing is that you can now use your SW data to produce visualizations.
If you go to my site, I have more info on the Solidworks to modo transition. Also if you plan on getting modo and the SW kit, you should find a discount code there.
http://www.mccroreydigital.com
Paul
