HI, I need help with something that must be simple. How do I insert more than one of the same component into an assembly. I have multiple fasteners and want to put them in and then mate them. All I can get is one in at a time. Could you tell the the steps?
When you go to Insert Component, click on the pin at the top to keep the command open, then when you select your component you can drop as many as you need.
