1 Reply Latest reply on May 23, 2011 1:46 PM by Jerry Steiger
    projected area?
    Nicholas Petty
      I'm using Flow Simulation to determine the Lift and Drag of a reentry vehicle.  In order to determine the coefficients of lift and drag, I need their respective projected areas.  Can Solidworks calculate projected area?
        • Re: projected area?
          Jerry Steiger
          Nicholas,
          Not directly, you will have to do part (most) of the work. You will need to project your bodies onto the planes. You will probably need to generate silhouette lines on your part with the Split Line tool, using the Silhouette option.Put sketches on the planes, then generate the outline of your body by Convert Entities using the silhouette lines. Check to make sure that the sketch outline is closed. Close out the sketch and use Tools/Section Properties to measure the area of the sketch.
          Here's hoping there is an easier way.
          Jerry Steiger
