Toolbox Question
Question asked by John Blaschke on May 20, 2011
Latest reply on May 20, 2011 by John Blaschke
Goal: I want to be able to save nut, bolts, washer coming out of the toolbox as part #, as I bring then in to my ASM.
I think this will require a two part answer. Question 1) how do you change the prop. of toolbox from READ ONLY?  When I go to save a bolt in my ASM, SW always let me know that this is a read only file. So how do I change from Read Only too…..
Question 2) I bring bolt into ASM, I save bolt as a 1XXX-XXX part num. everything looks fine. Do the same w/ washer and nuts. I save ASM, I close ASM.  I open ASM. And all my nut, bolts, and washer loose the file name I gave then and convert back to toolbox name….  Also, the toolbox icon is still there even though the bolt has its own part # and yes I’m save these parts in different loc. than toolbox.
I spoke w/ tech support and I tried to remove tag (icon) via running “sldsetdocprop.exe”  I must be doing something wrong because it still does not work.
Any Idea’s
