I'm having a problem with promoted parts not showing up on the BOM. The BOM is a top level only type. The same promoted parts show up fine on other BOM's. Here's a little history in case it matters:
I have to assemblies, A and B, that are very similar and share most of the same components. I completed the assembly drawing for A and saved it under two different names, A and B. I then went into SolidWorks Explorer, opened up drawing B and replaced assembly A with assembly B. I opened up drawing B, updated it, and noticed that the promoted parts in a particular subassembly no longer appeared in the BOM. I tried deleting the existing BOM and recreating it, but it didn't help. Any suggestions? I'm running version 2010 x64 edition, SP5,0.
Greg,
Go to the document properties of these parts and make sure the "Exclude from BOM"
is not checked.
