I have a somewhat complicated workflow includingt workflow links and automatic transitions. I am finding that my initial transition comment is beuing set to "State changed by automatic transition." I cannot figure out unders what circumstances this happens. I have other automatic transitions where the comment is left alone. A typical file histor5y looks like this:
Event | Version | Comment |
Revision: 0 | 5 | |
Transition from 'Approval Pending' to 'Approved' | 5 | State changed by automatic transition. |
Checked in | 5 | |
Checked in | 4 | |
Transition from 'Release Pending' to 'Approval Pending' | 3 | State changed by automatic transition. |
Transition from 'Assigning Oracle Number' to 'Release Pending' | 3 | State changed by automatic transition. |
Checked in | 3 | INITIAL RELEASE |
Renamed from 'Draw1.SLDDRW' | ||
Moved from 'C:\_EPDM\Engineering\Projects\123456-TEST PROJECT\4. Mechanical WIP' to 'C:\_EPDM\Engineering\Oracle\499xxx' | ||
Transition from 'Release Pending' to 'Assigning Oracle Number' | 2 | INITIAL RELEASE |
Checked in | 2 | |
Transition from 'CAD Work In Progress' to 'Release Pending' | 1 | INITIAL RELEASE |
Initial transition to 'CAD Work In Progress' | 1 | State changed by automatic transition. |
Created | 1 |
As you can see, on the automatic transiton from 'Assigning Oracle Number' to 'Release Pending', the comment is clobbered. However, a previous automatic transition ('Release Pending' to 'Assigning Oracle Number') leaves the comment alone.
Does anyone know the conditions under which the comment gets replaced? I have been trying to duplicate the problem with a simple test workflow, but have not been able to recreate the issue.
Jim S.
JIm, I am confused too. How did the user input the comment "INITIAL RELEASE" when the file automatically went through the first automatic transition that did not clobber the comment?
