公司是在去年2010年六月間向台灣的代理公司買SolidWorks的使用序號,
使用的版本為2010版
正常來說,在今年六月底才會到期,想問的問題是,
假如到期前的更新檔是到SolidWorks 2011-SP5.0
在序號到期後,才安裝SolidWorks2011版本SP0.0,
是否可直接更新到SP5.0的版本?
請各位先進幫忙回答,謝謝!
使用的版本為2010版
是否可直接更新到SP5.0的版本?
請各位先進幫忙回答,謝謝!
使用的版本為2010版
是否可直接更新到SP5.0的版本?
請各位先進幫忙回答,謝謝!
This is English Version Of above:
Is the last in June 2010 between the agent to Taiwan to buy the use of SolidWorks serial number,
The version used for the 2010 edition
Normally, will expire at the end of June this year, would like to ask the question is,
If before the expiration of the updates is to SolidWorks 2011-SP5.0
After the expiration of the serial number before installing SolidWorks2011 version SP0.0,
It can be directly updated to SP5.0 version?
Advanced help please reply, thank you
Thanks again Ajay for the translation.
Chung,
The latest version of SW 2011 is SP 3.0
I think what you are asking is if you an upgrade your version of SW from 2010 to 2011
and go directly to SP 3.0 from 0.0 before your maintneance agreement runs out
The answer is yes. 2 things come to mind. First is if you still have a maintneance agreement
then they should have sent you the 2011 DVD's already back last November. Install it at 0
then under the down load portion of the portal go get SP 3.0
Second is you can download directly from the portal the full version of SW at SP3.0
Hope this helps you. Good luck.
Thanks for your answer.
So, If my maintneance agreement already runs out,
could I upgrade from SP 0.0 to SP 3.0?
This is what I really need to know about.
Thanks.
Download access to Service Packs is only available to users with a current subscription. If your subscription has expired and you have not already downloaded the SP, you will have to request a copy of the SP from your VAR or SolidWorks.
下载存取服务包只适用于提供与当前的订阅用户。如果您的订阅已过期,您还没有下载的SP,你将不得不要求从你的SP VAR或SolidWorks的副本。
下載存取服務包只提供給用戶提供了當前訂閱。如果您的訂閱已過期,您還沒有下載的SP,你將不得不要求複製的SP從你的VAR或SolidWorks。
Chung,
